Status
Not open for further replies.
1 - 3 of 3 Posts
I've got the AT 350THX setup and I'm thinking of getting a new 6.1 or 7.1 reciever to replace my Sony 50ES. Any recommendations on what to buy for the rear center channel? I have not been able to find someone to sell me just the AT center channel
If your doing a 7.1 set up for THX Atlantic Technology recommends two of their dipolar surrounds on the back wall one third of the way from the side walls placing the diplole designated left, on the right side, and the right designated on the left side (reversed). If you get a THX Ultra 2 processor, then use direct radiators for the back two speakers. Check this link. http://atlantictechnology.com/interactive_room2.htm
I setup my 7.1 AT system as shown on the link. Sounds great. I mounted the sides and rears about 2 feet above my seated position, the resulting overhead pans are awesome.
1 - 3 of 3 Posts
Status
