There isn't a setup code specifically for the speaker, but there might be a way to program it in using a close setup code and advanced codes. Try this to test first:
First set the set up code for AUD to 1377. Then do the following:
1. Press and release AUD
2. Press and release SETUP
3. Point the remote to the speaker's IR sensor and type 00117 on the remote
When you press the last digit, the remote should send a signal for power on the speaker. If that works, I will post how to set the programming permanently along with the rest of the codes for the other commands. If you want to set the programming to a different device button (for example AUX) I can show you how to do that as well.
