1 - 2 of 2 Posts
· Registered
I was reading the manual of Pioneer 5020 and it says that it ships with Stand attached to it. However the speaker is not attached? To attach the speaker I have to lay the TV face down remove the stand, attach the speaker and attach the stand.
Am I reading this right?
I thought that Plasma TV's cannot be laid flat.
· Registered
You can leave the stand on. First, have someone hold the speaker where it goes and then you go behind and start putting on the brackets. Make sure to keep them all loose until all the screws are in and then tighten them all. Also, be careful not to cross thread them. It's very easy if you get someone to give you a hand. Then enjoy one of the greatest display on the market.
1 - 2 of 2 Posts
