Status
Not open for further replies.
1 - 3 of 3 Posts
I was wondering if anyone has ever seen, or knows where I can buy a 3-way splitter/adapter for a 1/8 miniplug. I need something to plug into the analog output jack on the back of my audigy 2 card. I need one for the Rear/Subwoofer/Center jack. I've searched and I can't really find anything. I'm trying to hook up my sound card to my receivor. I currently use the SPDIF output but am not happy with it.
Thanks in advance:)
This isn't exactly what you are looking for, but it might work. I know it works to break out the 3 digital sp-dif lines off the single digital port (which you probably don't care about and probably don't even know what the heck I'm talkikng about).
http://www.cablesamerica.com/product...5209&sku=29148
If you know someone with a mini-dv camcorder, chances are it came with a cable like this so you could borrow it and see if it works before buying.
1 - 3 of 3 Posts
Status
