I can't seem to get Audigy 2 SPDIF output to work at all.
Running Win XP, using the analog 5 channel output to a receiver works fine, but when I try to use the SPDIF output to a receiver, essentially does not work.
I've fiddled endlessly with soundcard settings (sampling rate, "Digital Output Only" enabled) etc. to no avail. Best I've gotten is a faint, scratchy output that is useless.
I don't even need AC-3 output- this SPDIF feed goes to a receiver that drives analog speakers in other rooms of house, so standard stereo output is fine.
Have also tried various cables:
1) standard 3.5 mm minijack on sound card end, RCA connections on receiver end
2) optical cable with 3.5 mm minijack on sound card end, Toslnk connection on receiver end
Have not tried going to coax input on receiver end, but I could not see how this would make a difference.
Standard CD source, MP3 file, does not make a difference, neither works.
Two receivers, neither works: Yamaha HTR-5560 and Denon AVR-683
Very much stumped on this one, as internal diagnostics (Creative diagnostic software) say all is fine.
Some people seem to have similar problems- any suggestions?
