LIVE: AVSForum Tech Talk Podcast with Scott Wilkinson, Episode 5 Click here for details.
Enter to be our Home Theater of the Month Click here for details.
Originally Posted by jkseger /forum/post/0
What would be your purpose for needing HDMI?
There is a pasthrough DVI jack that allows for a 7th out which would be able to do HDMI (via an HDMI to DVI converter) but as far as sending the signal across cat5 all they can do is send component right now.
John
PS. Trent, Murray, or RxMan1 please correct me if I'm wrong.
Originally Posted by emillika /forum/post/0
What does this mean in real-life? Will any adopters be SOL in the future? How far in the future? I don't follow the HDCP/HDMI happenings very closely.
I guess at the end of the day I don't want to throw away $4k in 12 months.
Originally Posted by Audio Authority /forum/post/9496860
Hello,
The main reason the AVAtrix doesn't have HDMI is that when we began design of the 1166 (part of the AVAtrix head end), DVI was the dominant connector format - HDMI was a bit of an upstart.
Transmitting component video over Cat-5e is easy - it can be sent long distances, in a balanced line configuration, and easily gain-equalized to correct for loss over those long distances. Doing the same to HDMI and DVI is harder, partially because those formats are distance-challenged anyway, and partially because there are so many conductors inside HDMI/DVI cable.
Let's do some math - HDMI cable has 19 conductors inside. Cat-5 has 8 wires, twisted into four pairs. Two Cat-5s equals 16 conductors.
Existing HDMI over 2xCat-5 solutions don't used a balanced line configuration, because to do a balanced line, you need two copies of each signal. That would take 38 wires (5 Cat-5s) to do. A non-balanced solution is vulnerable to noise, and a 5-cable system wouldn't be practical, so right now we're looking for another solution. Also considered are HDMI's continued problems with compatibility - inserting a matrix into the mix makes for some problems on some sources/displays. (There are some 2 x Cat-5 solutions that use 10gb Ethernet, which seems to be a more reliable way transmit HDMI over UTP).
So I guess our stance is that "we're working on it". Just remember that HDMI/DVI play by different rules than Component, and that means that solutions that work nicely for component may not work at all for HDMI. Keep checking the website!
