Status
Not open for further replies.
1 - 1 of 1 Posts
Hi,
What do you think is better for line level stereo analog audio (from
computer sound card to VCR) over a fairly long distance (around 15m/50
feet)? I have decided on either (based on price):
1xtwin screened mic/line cable (most expensive)
2xRG6 75ohm braided+foil shielded & foamed polyethylene (I think, it
looks and feels a bit like foamy polystyrene) insulated coax (moderate
price, but normally the most expensive, it's on sale although maybe
not so expensive if bought in bulk)
2xCoax Cable RG59 TV & Video 1/0.8mm copper + Foil & 68% Braid
(cheapest) [this is actually designed for satellite TV and such so
it's probably a bad idea]
My prelimenary thoughts tell me that the twin screened cable is better
to minimise ground loops. However the both 75ohm will probably have
less crosstalk and will probably shield against interference better
and have less attentuantion (assumingly the RG6 will be the better of
the two)?
I know you can't say for sure without the exact specs of the cable but
if you could tell me what would you think in general please, it will
be very helpful.
I will try to find out what the twin screened cable is. I think it's
Proel but not sure which one. However I will try to find out on Monday
and will post it if that will help. As for the RG6, well I can't find
out what that is. Ironically I have some here with me but all it says
on it is RG6/U COAXIAL CABLE. It's black :) As for the RG59, well
that's about all I can't find out.
Thanks all.
1 - 1 of 1 Posts
Status
