For the marginal increase in cost, you might consider the EFT5 software. I have it sitting on my floor, but have not used it yet. I just got my system up and running, and, frankly, it sounds so good already I have not been that motivated to take a half day to set up my computer and run all the tests. Word-of-mouth is very good on the software. Others on this forum and on Audiogon say they have gotten spectacular results. It runs on your PC, and costs $299 Canadian (about $260.00 US at current exchange rates). It generates the test tones (pink noise, white noise, sweep tones), and not only includes a spectrum analyzer (which is instantaneous information) but also provides time information in the form of "waterfall plots" (showing the time it takes for each frequency to decay,which really tells you where reverberance is coming from. This is useful for room treatment placement and EQ settings). It also provides a bunch of other information I am even not sure what to do with. To run the program you will need a calibrated microphone and a cable, which you can get at Guitar Center or other musician-type stores for maybe another $150.00. If you know any musicians with home studios, you might even be able to borrow the mic and cable. This seems to be the cheapest and most scientific approach. I figure it will take me a half day to run all the tests to determine speaker placement, crossover points, and settings for my Meyer Sound parametric EQ. I will give a full report on the results when they are done, but it may take a few weeks before I gear up for the project. I am too busy listening to music and watching movies to spend alot of time tweaking right now.
