Status
Not open for further replies.
1 - 4 of 4 Posts
· Registered
Anybody know why I'm experiencing about a two or three second audio dropout after the splice when I use Shorten Segment? Is this normal? Is it fixable? It's certainly annoying.
-Chris
· Registered
Discussion Starter · #3 ·
As I read the thread, I don't think that's it. There's no pause in the video, just audio dropout. And strangely, the audio has a quick little fade up at the end of the silence. And and far as the I-frame stuff goes, this is a three second delay, not a three frame. Thanks though.
-Chris
· Registered
You don't get a pause when the audio dropout happens. You have seamless play on. Turn it off and you will not get the dropout, but you will get the pause.
1 - 4 of 4 Posts
Status
