Status
Not open for further replies.
1 - 7 of 7 Posts
Has anyone else experienced audio dropouts on the DST3000? I evaluated the unit for a week and noticed numerous dropouts on my local CBS station. I do not get these with my Dish 6000 or the Panasonic HDS20. Any thoughts?
Gary
Premium Member
I get neither drop out. I believe it might have to do with the signal strength. On my DTC-100 I had audio dropouts. On the DST3000 my signal went up to 100% on OTA and mid 90's satelite. Much stronger than the DTC and the dropouts are gone.
Everyone should keep in mind signal strength is a relative thing. A 90 on one unit could be 70 on another. You can't compare these numbers across manufacturers. Even unit to unit is relative.
I'm Porky Pig of Borg you will be assim-assim-assim- absorbed.
Premium Member
Maybe it has to do with are Audio Receivers pulling in the signal or the DST3000 receivers themselves.
I have also been experiencing occasional audio and video dropouts (always simultaneously) on my DST-3000. However, I have only noticed them while watching HDTV broadcasts, so I figured it was the local broadcaster's problem, rather than mine.
If someone knows differently, I would be very interested to learn about it.
1 - 7 of 7 Posts
Status
