Originally Posted by Don Landis /forum/post/20827807
While the M+S ( if a 3 channel recorder is used) can improve stereo separation, what sort of shooting environment would benefit from such an arrangement other than special gimmick effects?
Hey Don, I've worked with audio for a long, long time (mostly for video game and virtual reality (3D audio); interactive, real-time synthesized applications). I had seen M+S over the years, even have a Sony MS957 M+S stereo mic, but never really looked into it further. When I read how it works, it was one of those- 'sounds too good to be true' moments. Since the MS957 only outputs normal stereo (M+S converted to stereo: the 90/120 degree switch controls how the M+S is processed into stereo), I had no way to test it, so I picked up a $90 ribbon mic (to get the required figure 8 pickup pattern). It works, and works well. The 'stereo zoom' mics of video cameras use M+S to go from wide stereo (zoomed out) to near-mono (zoomed in).
I haven't worked in broadcast, but apparently M+S is very common as it is also mono compatible. The Audio Technica 4029 can output normal stereo, or the raw, unprocessed M+S (just 2 channels). From those two channels you get L+R+C in post. 3 for the price of 2, sounds too good to be true, but it really works. Being able to smoothly control the stereo field in post is amazing.
Check this out:
http://www.recording-microphones.co....d%20Side2.html
You don't need plugins- M+S can be done with any DAW (though there are some pretty sophisticated & powerful M+S plugins).
For 5.1, you just need to add another unidirectional mic and do the same mixing with the figure 8 mic to get another 2-3 channels facing the rear (.1 (LFE) is just the low frequency component of all the mics). So for 5.1, you do need 3 recording channels. I have shot separate audio before using the Zoom H4N. It is more work but the audio quality is much better than on-camera (on camera can be greatly improved using something like a JuicedLink:
http://www.juicedlink.com/ ).
While this project didn't use any camera audio, the video was from a consumer Canon HF11:
http://www.myspace.com/internetexplorer (see the center video, "HD Video"): just another example of using low cost consumer gear in commercial work (I had much higher quality video I shot on a Canon 5DmarkII of the Long Beach Grand Prix; couldn't use it as we couldn't get permission in time (found out afterwards- just need to purchase a photo-pass ticket to get rights)).
When I started my company back in 1997, I put together a $40k ProTools- based sound studio. During the dot com bubble of 2001, I sold the ProTools gear and have found I can get excellent quality from much lower cost tools. Products from Neumann (now part of Sennheiser (for a while now!)), Gefell, MBHO, Sanken, Schoeps, Sound Devices (
http://www.sounddevices.com/ ) are interesting, but until the extra quality warrants the extremely non-linear increase in price, I try to find solutions which provide good enough quality before the cost curve looks like a hockey stick. Now that I can effectively remove broadband noise in post, with lots of EQ options, relatively low cost mics can produce good enough results.
For the hot shoe, I have an external "5.1" mic that Sony offers and works for the TD10.
Sounds interesting- will have to check that out.
So, in my view, once you cross the line to professional 5.1 recording of sound on your projects, you not only need to haul along the pro mic but also use a separate recording device, then sync that up to the camcorder video using the camcorders internal audio channel for sync purposes only.
Definitely more work, but worth it if producing something intended for commercial applications (or even just to learn the technique). I've got clapper board software running on the iPad which helps make sync easier (there are also plugins which use audio cross correlation to automatically sync audio tracks (FCP-X, IIRC, has this built in)).
