I downloaded a FLV file and when I convert it to an AVI as long as I don't try to change the resolution it converts Fine. The minute I try to change the resolution the audio gets out of sync. I've tried several programs(Quick media Converter, free FLV converter and AVS Video converter) Any idea why changing the resolution causes the audio to be out of sync. I tried changing it to 624x352, 640x360 and 1280x720 (using xvid codec) all out of sync. Here is the Files info according to QMC.
Format : Flash Video
FileSize/String : 304 MiB
Duration/String : 2h 24mn
OverallBitRate/String : 294 Kbps
Video
Format : H.263
Width/String : 320 pixel3
Height/String : 240 pixel3
DisplayAspectRatio/String : 4/3
FrameRate/String : 25 Config_Text_FloatSeparator000 fps3
Bits-(Pixel*Frame) : 0.000
Audio
Format : MPEG Audio
Format_Version : Version 2
Format_Profile : Layer 3
BitRate_Mode/String : CBR
BitRate/String : 64 Config_Text_FloatSeparator0 Kbps
Channel(s)/String : 2 channel2
SamplingRate/String : 22 Config_Text_FloatSeparator05 KHz
Resolution/String : 16 bit3
Video_Delay/String : 8s 40ms
Thanks in advance any help will be greatly Appreciated.
Video
Format : H.263
Audio
Format : MPEG Audio
