1 - 2 of 2 Posts
· Registered
So I am eventually going to upgrade my old DVD/CD player with a new Blu-ray player. I'll use it for both audio CDs, regular DVDs, and Blu-Ray.
For audio, I currently have my DVD player hooked up by digital coax straight into the receiver, there's IR available on both. But I already had the digital coax. Video is using component cables.
Anyways, lots of Blu-Ray and DVD players advertise "great" DACs. Question, so if I am using the coax or fiber digital audio out, isn't that basically just skipping the DAC in the player completely? Using the one in my receiver instead? Or am I missing something. If I were to use the internal DAC in the blu-ray player, what outputs are used?
I've always figured there would be less "noise" going pure digital until I hit the receiver. Seem's like a bad step to first convert it to analog, and then run that analog signal to the receiver.
· Registered
Revel M22 & C32, JBL P520WS, Revel W563 & Infinity ERS 110II, SVS SB-2000 (x2), Anthem MRX 720
I've seen some universal players touting their DACs, but you're basically right, this is useless for S/PDIF or digital coax output. If you are playing DVD-Audio and Super Audio CDs, that's different. Some folks that want to hear the HD audio on blu-rays also need multichannel analog outputs if their receivers don't accept multichannel PCM over HDMI.
You need to decide if you want lossless blu-ray audio. If so, and your reciever can't handle multichannel PCM, then you need to find a blu-ray player with DACs. Almost all new receivers these days can internally decode the HD audio tracks. If this is what you have, your blu-ray player is primarily going to be a transport. No need to overspend.
1 - 2 of 2 Posts
