1 - 1 of 1 Posts
Hello, does anyone know if there is a way to get an audio output signal from a HTIB system. I just want to be able to route a signal to an external amplifier so I can run speakers outside on the patio.
As far as I can figure out it might be possible using ARC and getting an HDMI digital to analogue RCA converter. But I've not been able to test this. Whilst in shop I could send sound to a television as a test, but it only worked with the DVD audio. When I tried with the blue tooth connection, and the aux input it no longer sent any audio via the HDMI to the TV. I tested it with some Samsung and LG Blu-ray HTIB systems.
Is this an unsolvable problem?
Thanks if you can help.
1 - 1 of 1 Posts
