1 - 2 of 2 Posts
Your audio output of the UVerse settop should be at a fixed level (MAX volume), there should be a setting under audio control. What happens if this isnt set you overdrive your TV speakers because they have a low input level resulting in a low hiss behind the audio and then when you change sources your sound blasts out an you have to make volume adjustments.
1 - 2 of 2 Posts
