Hi,
I know this question has been asked before, but I still have a question.
Ik bought the logitech z906 (5.1) which can process dolby and dts. It is connected to my ps4. It is connected with an optical cable.
Ps4 setting: pcm, dts or dolby. I understood that I need to select dts or dolby, when using an optical cable (pcm is stereo). But when using pcm I still have surround, granted less noticable than dolby or dts.
Ok, so I need to select dts or dolby. I understood that it doesn't matter which one. But why? My games can support both, but most of my dvd's only have dolby. So isn't is bad when I use dts in this example?
Furthermore, when playing a dvd, I have the option to select pcm or bitstream mix or direct. Why can I select this again in the ps4 dvd menu? I don't understand why I can select pcm while watching dvd, and still have dolby selected in the ps4 settings?
So I ask the question again, what is the best selection? Pcm and dolby/drs sound quite different from each other.
