1 - 2 of 2 Posts
AUDIO OUTPUT SWITCHING
I have a Onkyo TX-NR727 receiver. Audio outputs are needed to a Polk Audio TL1900 5.1 speaker system AND a Sennheiser RS160 wireless headphones. I need to switch between these outputs to use one or the other separately. I have the 5.1 system worked out OK but how do I turn off the speakers and switch to the headphones?  Do I need a switch for this or can I switch outputs at the receiver? Can anyone recommend a switch with minimum loss? If at the receiver, which output connection should I use for the wireless headphones? Thanks
1 - 2 of 2 Posts
