1 - 5 of 5 Posts
I bought two Aura shakers and hooked them up. For some reason I can't seem to get them to shake. I assume any one of the bass test flac's in the site below will be just fine for testing purposes right?
http://sinan.ussakli.net/basstest/
I wired my shakers in series according to this:
http://www.avsforum.com/avs-vb/showthread.php?t=330436
The only difference is that I'm only using 2 shakers attached to the right channel. This is ok right? How many watts can two 50 watt shakers handle in series? If the Ohms goes from 4 to 8 due to wiring in series does the wattage stay at 50 or does it go up to 100?
Thanks in advance,
W
Discussion Starter · #4 ·
I have the low frequency output from one receiver feeding a second receiver. It's this second receiver that is connected to the shakers.
in the diagram below red means positive and black is negative of course. LFE is low frequency effect output
RECEIVER ----LFE----> RECEIVER (red)-----(red)Shaker(black)----(red)Shaker(black)---[back to the black plug on the receiver]
Discussion Starter · #5 ·
I solved the issue. Apparently the B channel isn't as good as the A channel on my receiver. Tested the channel out with a regular set of speakers and noticed a big difference.
1 - 5 of 5 Posts
