Hi everyone,
I am new to the board and am a HDTV novice right now, but come from a technical background. I do have a question though.
I plan to get an HDTV, and was thinking about a 30" wide-screen HDTV to replace my 27" SDTV. Then I realized that all my 4:3 viewing will be 24-26" if I don't want to stretch it. So I figured a 32" 4:3 HDTV would be the best solution (~29" wide screen view in 16:9 ratio and the full 32" in 4:3 ratio).
My problem is understanding how the HDTV or HD cable box (in my future case) will display a channel in the correct aspect ratio. Does it auto-sense the display format? If so, is this dependant on or performed by the TV or cable box. For example, I put a DVD in my player now, and it shows up with black bars on the top and bottom, which is fine with me. Will this still happen on a 32" 4:3 HDTV (I hope)? What about changing channels between SDTV and HDTV? I don't like 16:9 programming stretched vertically on a 4:3 or 4:3 programming squashed on a 16:9 widescreen. My biggist concern is if it does detection on the fly, or if I have to switch video inputs or click a button every time I switch between normal 4:3 programming and widescreen programming.
Thanks everyone!
Thanks everyone!
