Hello
I have a project whereby I need to look at upgrading an existing AV Distribution system. However I need to keep a few things in mind before I can go ahead and upgrade it. I would like to ask for support and advice on what system(s) to look at which will match what I am looking for.
The points I need to keep in mind (as the distribution system must be able to handle these) are:
1) Split Projection
In the first room: 2 projectors capable of simultaneous projection.
In the second room: 3 projectors capable of either centre only, left & right projection, or any combination thereof.
2) Ability to mirror projectors from one room to the other with 2-way audio.
3) Each room must be able to operate independently of the other.
4) Video preview of the currently selected source must be displayed on the touch panel.
5) Video sources must be able to be annotated over on the touch panel. Annotations made this way must also be projected.
6) Both rooms must be able to be monitored remotely using the existing Fusion RV and RMS monitoring systems.
7) All aspects of both rooms must be able to be controlled remotely.
8) Any video source must be able to be routed to any output with no restrictions.
9) Audio source selection must primarily follow video selection, however must also be able to be independently selected.
10) All equipment must be 2-way controlled, preferably over RS-232 where available.
The Distribution centre must be able to handle different sources
1) Mac, PC, Latop, Wireless Microphones, Projectors etc.
2) It must also be able to handle HDBaseT, HDMI, VGA+Stereo Audio input/output and 100V Line Stereo Audio & 100V Line Mono Audio
3) Banks of individually controlled lighting
4) Dimmable functionality
With the above in mind, I am looking at a system that is the next level to the above. Something that can handle the above while providing features for future-proofing so when better cables/audio/video etc comes out.
I understand this is quite a challenging project, but I would appreciate ideas and suggestions of A/V distribution models available on the market in order to allow me to investigate further.
thanks
Hello
1) Split Projection
thanks
