Not sure if this player has been discussed here but saw this in my local PC shop being sold for less than US$250. Don't know if its multi-region capable since its Japanese (probably R2 only not sure)
http://www.iodata.jp/prod/multimedia...2003/avlp1dvd/
http://babelfish.altavista.com/babel...%2Favlp1dvd%2F
"AVeL LinkPlayer (the アヴェル link player)", you record in the personal computer and by way of the network to enjoy with the television and the audio equipment it is possible the various image picture audio contents which are accumulated, it is the media player. DVD drive is loaded, DVD video of course, can play back also image and the picture and the audio file which are recorded to DVD and CD that way. "AVeL LinkPlayer" is the convenient network media player who connects the personal computer and the AV equipment.
AVeL (アヴェル), the eye o data lectures,
It is the product series which actualizes "Audio Visual for e-Life".
You can experience operation!
|instruction manual|driver|Q & A| You can view the rear terminal of completeness, with illustration. >>> specification
You see with the television, the れ る! It corresponds to® colorful type such as MPEG-1/2, DivX VIDEO, XviD, JPEG, WMA and MP3!
* Therefore hardware decoding system, as for image indication being natural, smooth. In order the original animated picture file to play back with "AVeL LinkPlayer" that way, CPU load of the personal computer which is retained is little, there is no either picture quality deterioration with re-conversion.
* It corresponds to the various compressed formats. If the compressed data be able to save the CD/DVD media, storage the compact.
* Corresponding data format
Video format
MPEG-1/2/DivX® VIDEO/XviD
Picture format BMP/JPEG/GIF/PNG
Audio format WMA/MP3/MP2/AAC/AC3/PCM/OggVorbis
-> As for details please view "the corresponding media corresponding data format" of specification. >>> specification
*The part format converting on personal computer side, becomes playback.
With high functional server software "AVeL LinkServer", comfortable network playback!
"AVeL LinkServer" is image in "the AVeL LinkPlayer" empty personal computer and the server software which actualizes the access to the picture and music. At personal computer one "AVeL LinkServer" is installed, plural "AVeL LinkPlayer" can be utilized.
- It installs "the AVeL LinkServer" software to the personal computer, with accesses "AVeL LinkPlayer" empty network.
- If the wireless LAN adapter is installed in the PC card slot the rear, even at the room which is far it can access with the radio.
Corresponding wireless LAN card: This corporation make 802.11b corresponding 11Mbps wireless LAN adapter "WN-B11/CFL" (selling separately)
* Compact flash adapter "PCCF-ADP" (selling separately) is necessary. It updates the information of correspondence of the wireless LAN adapter on occasion.
* At the time of radio connection the reproducible video file becomes maximum 3Mbps. There are times when in addition, network environment and with the state of the data, the scene falling etc. occur.
The digital camera photograph which enters into the memory card ラクラク!
* If the memory card where the digital camera photograph enters into the PC card slot the rear is installed, that way sliding show and it is possible to play back selectively.
*As for playback function of memory card with update of future firmware correspondence schedule.
*The separate PC card adapter is necessary. This corporation make memory card, as for the PC card adapterplease view this.
Main attachment item
Remote control, single 4 electric battery ×2 (for remote control), AV cable and LAN cable, support software (CD-ROM)
Corresponding type (type name) The NEC PC98-NX series/DOS/V machine
Apple PowerMac series
Hardware requirement
CPU Above Intel Pentium III 500MHz
Interface Ethernet port (100BASE-TX/10BASE-T)
Memory Above 128MB (recommendation above 256MB)
HDD The being less crowded capacity of lowest 50MB
*As for the Apple PowerMac series, the type where correspondence OS operates
Correspondence OS Windows XP, Windows Me, Windows 2000 Professional and Windows 98 SecondEdition
MacOS 10.3
Interface
Video output Output terminal
Composite video ×1
S video ×1 *in S2 standard non correspondence
D4×1
1080i/720p/480p/480i
DVI-I×1 640×480 (VGA)/800×600 (SVGA)/1024×768 (XGA)
852×480/DVI 480p/DVI 720p/DVI 1080i
*DVD-Video is not output.
Aspect ratio 4:3 pan scan, 4:3 letter boxes, 16:9 wide
*As for DVD video aspect ratio and DivX VIDEO/MPEG-1,2 which® correspond play back at aspect ratio when encoding
Audio output Analog stereo (RCA pin-jack terminal) ×2 and S/PDIF (optical terminal ×1 and coaxial terminal ×1)
Network
LAN port 100BASE-TX/10BASE-T port (RJ-45) ×1
IP address Automatic operation and acquisition (DHCP client function)
Manual setting
*Wireless LAN adapter PC card available (description below)
PC card slot PCMCIA TypeII conformity ×1
Wireless LAN card
This corporation make 802.11b corresponding 11Mbps wireless LAN adapter "WN-B11/CFL" (selling separately)*
Memory card This corporation make memory card*
*The separate PC card adapter is necessary.Please view this.
Rear terminal
Point: The D terminal equipment which it is easy to use. Analog voice response terminal at two concurrent connection to also ミニコンポ OK!
*You cannot use the image output terminal simultaneously. Respectively it becomes utilization with exclusion.
Corresponding media corresponding data format
Video format
Standard of maximum bit rate, with MPEG-2 of the going by way of of network or DVD media with 8Mbps and the CD media becomes 4Mbps. At the time of radio connection it becomes 3Mbps.® DivX VIDEO approximately 1.5Mbps is standard.
In case of in each case network environment and with the state of the data, there are times when the scene falling etc. occur.
*It can play back XVD, WMV and ASF by the fact that it converts to MPEG-1 with Media Sink.
Media DVD+R/DVD+RW/DVD-R/DVD-RW/DVD-ROM
CD-R/CD-RW/CD-ROM
*You can use also 8cm CD.
*It cannot play back DVD-RAM.
*Quality of the media, with the circumstance of lighting, part there is a media which cannot be played back.
DVD player function
Corresponding standard DVD-Video/Video CD/CD-DA (Audio CD)
*The DVD+RW media which records with the DVD+VR format is not yet correspondence.
*It cannot play back the DVD-RW media which records with the DVD-VR format.
Playback function
Playback/halt/stop/fast forward/you reset quickly,/the following chapter/chapter before
Title chapter selection playback and time search function, repeat playback and slow playback
Multiple angle, language selection, subtitle selection and setting of viewing restriction
Audio playback system Stereo PCM/Dolby Digital AC-3/DTS*
*Being digital, it outputs. The separate DTS decoder is necessary.
Region cord/code 2 (fixing)
Operation button Power source/disk removal
Playback/halt/stop/fast forward/you reset quickly,/the following file/the file before
External size 430 (W) the ×250 (D) the ×48 (H) mm projection ones you exclude
Power source AC100V 50/60Hz
Category temperature range (℃) 5 - 35
Operating humidity limit (%) 20 - 80
Installation condition Horizontality
Guarantee period 1 year guarantee
Various acquisition standards
Export management stipulation As for this product strategic material there are times when such as "foreign exchange it corresponds to the export regulation product and depending upon the stipulation of foreign trade method".
The case where you bring up overseas, there are times when procedure such as export license application of the Government of Japan becomes necessary.
Remark Even with the file of the corresponding format, there are times when it cannot play back just with compression setting and the like.
DivX and the DivX logo are registered trademarks of DivXNetworks and Inc. in the USA and other countries.
In order for us to deliver better product information, the questionnaire is executed. Please cooperate please.
Video format
MacOS 10.3
Interface
Composite video ×1
D4×1
Network
Manual setting
Wireless LAN card
Rear terminal
Video format
CD-R/CD-RW/CD-ROM
DVD player function
Playback function
