The test tones that you get from those test discs are typically more accurate than the internal tone generators with receivers. That's partly because most of the internal generators output a wideband test tone that includes the low frequencies. When sent through the main, center, and surround speakers, this creates greater interaction with the room acoustics and can potentially distort the SPL readings that you get.
Avia uses a narrower band test tone that avoids the low frequencies, and is less prone to room-induced errors. Not sure if their subwoofer test tone has any built in adjustments like the DVE disc.
Also, keep in mind that the accuracy of that SPL meter decreases as you go further into the lower frequency ranges.
