ok, so i've searched around and i've found threads that say to use avia over receiver tones because a calibration using avia tones includes your source and the tones are being decoded/processed by the receiver the same way a dvd will be when watching a movie. that makes perfect sense to me and i pretty much assumed it, even before i'd read/confirmed it.
i've also read multiple threads that say to use audessey over receiver test tones and an spl meter, because audessey takes a lot more things into account, and eliminates the inaccuracies found in cheap spl meters. again, that makes sense.
BUT, what about audessey versus manual calibration with avia? especially when you have an older version of audessey, like my onkyo 603 does, that uses the receivers pink noise test tones - not frequency sweeps - to do it's calibrations? if you use avia, you eliminate the negatives of the receiver generated tones, but you lose out on audesseys complex calculations, and you include the inaccuracies of the meter. on the other hand, if you use audessey, you negate the inaccuracies of the meter, but you lose the "full path calibration" aspect and (in my case) you're using the lousy receiver tones. so, which would you rely on if you were me?
