Hello. Here are my specs
Core 2 Duo E8400 3.0ghz
X1950 PRO 256DDRAM3
4 GIG OCZ DDR2 800hz
80gig - WinXP
500gig - Vista
So I have the option of booting into either XP or Vista.
On XP, I can change the color , do interlace and everything in the AVIVO tab in the Catalyst driver. Which means, when I play a video I can change the brightness , contrast right away. I play alot of mkv or HD stuff.
On Vista , I try to adjust the settings in AVIVO but it does do anything to the videos being played.
I googled and learned that you need certain decoders etc. On the XP boot, I found out that the decorder was set to CyberLink Video/SP Decoder (PDVD8. So I downloaded K Lite and use VMCD along with DECCHECK to set the default codec to CyberLink.
It did not work. I even set it to ATI Mpeg decoder, and it still doesnt work. I cant seem to get AVIVO to work on the Vista boot. It works fine on the XP boot. I boot into Vista and just keep XP as a back up. But I want to use AVIVO to change the contrast and color. I'm not asking to use the hardware acceleration because I already know media player classic and VLC does not support it.
Conclusion...
I want to use Media Player Classic to play mkv etc.
Downloaded K lite codec. The files play.
I want to change the color , contrast etc in the AVIVO setting.
Does not work for Vista but works for XP.
Please help.
X1950 PRO 256DDRAM3
80gig - WinXP
500gig - Vista
Conclusion...
Please help.
