1 - 4 of 4 Posts
Hi there, I have the Denon AVR 3313CI receiver which has been great to date. One thing that just started happening is that when I try and turn the receiver off with the button on the front of the unit it just toggles between main zone on or off when tapping the button. This used to turn the unit off so I'm not sure what went wrong. At the moment I have to unplug it to power it off which is a bit of a nuisance. Any suggestions? Many Thanks.
use the remote?
do you have another zone on?
is the unit still under warranty?
Warren
Look in the setup menu for Options and a way to lock the front panel.
Premium Member
This simply means you have either or both Zones 2 and/or 3 turned on. Set them to OFF and you'll have your power button working again. :)
For more helpful information on your 3313CI, join us in the Denon XX13 Owner's thread, reviewing posts 3-6 in that thread for more helpful information.
http://www.avsforum.com/forum/90-re...13-model-owner-s-thread-faq.html#post21995255
1 - 4 of 4 Posts
