That depends on whether the nr1711 is slightly coloring the sound to be more pleasing or not most likly.
How much do pre amps colour the sound? Is the colouring not mostly done by the power amp? Or both?That depends on whether the nr1711 is slightly coloring the sound to be more pleasing or not most likly.
Looking at either the Model 30 or PM8006.What amp are you using?
The PM8006 has a 250mV sensitivity on the line input which is plenty low for either of your listed AVRs to drive. The only real SQ difference I'd imagine being relevant between the 1711 and the 5015 is the different versions of Audyssey, with the 5015 having XT.Looking at either the Model 30 or PM8006.
Preamps should be the sole device that color the sound. The amps, if they're proper should be completely transparent - their only job is to make a signal more powerful, and any colouring the amp does is known as distortion, considered bad.How much do pre amps colour the sound? Is the colouring not mostly done by the power amp? Or both?
