I'm trying to choose a wall mount for my Pioneer PRO151 being delivered next week. I'm torn between choosing a standard cantilever wall mount like the following Chief product:
http://www.chiefmfg.com/productdetai...ProductID=2296
OR
the following "automated" Chief product:
http://www.chiefmfg.com/productdetai...roductID=25846
Price isn't an issue as I have found both of these products selling new for just over $300.00. Not bad considering they list for closer to $800.00
I know Chief's quality is suppose to be top notch and it's reflected in the reviews. For my mount location, I cannot mount an "in wall" style mount otherwise that would've been my first choice. I only require a small amount of tilt and left turn/right turn travel, so both would work fine. I do like to move my monitor's slightly depending upon which side of the room I'm sitting on, so the automated mount with it's 2 preset's sounds rather appealing. I just don't know if this style mount lends itself to break downs or other issue's.
So, has anyone used this or any other "automated" style wall mount? Would you buy this automated mount, and why or why not?
OR
