1 - 4 of 4 Posts
· Registered
Have an AVR 507 with original firmware (1.0?) that has performed pretty flawlessly over last 7 years (aside from intermittent lock ups). Recently upon changing from Comcast cable to Verizon FIOS, the new Verizon Motorola STB's digital audio outs do not work with the B&K's S/PDIF inputs, coaxial or optical.
The STB is outputting fine as the optical cable is lite and the original input on the B&K works fine with the previous STB from Comcast (a Pace and SA) as well as a DVD player. Is there a difference in the digital audio stream from the Moto boxes that could cause the B&K to not work? Would one of the B&K pricey upgrades fix this?
· Registered
I have seen this a LOT.
The B&K's dont like the Fios spdif & neither do older NAD's
An firmware update chip may fix the problem.
But really you should also make noise w/ verizon because the problem is on their "dirty" signal.
Call your local dealer.
We have been selling most of our clients the new ref70 / 707.
So lemme know what happens in your case.
· Registered
Discussion Starter · #3 ·
Will do - just sent the unit in to B&K for a firmware upgrade. Unit was still on original version 1.00 as I did not want to send the unit in and lose it for a few weeks. Hopefully this fixes the issue, because getting Verizon to fix their end will be interesting.
· Registered
Discussion Starter · #4 ·
Got the upgraded AVR 507 back from B&K with the latest firmware and problem solved. Digital audio works fine from the Moto STB boxes and the clicking when switching sources is gone.
Still very impressed with a 6 year old AV unit that is upgradeable and still sounds and operates great from a responsive company who got my unit back in less time than promised.
1 - 4 of 4 Posts
