Status
Not open for further replies.
1 - 3 of 3 Posts
I am looking for a HD lcd projector. I am deciding which one to get
the panny 700 sanyo z3 etc. Can any of you owners out there tell me if
any of these can be viewed with a few lights on.I have read numerous reviews but would prefer first hand knowledege.
Simple answer... You can have a LOT of light on in the room as long as it is directional and none of it makes its way to your screen. Track lighting and recessed lights with spot bulbs work very well. Room lamps and overheads with omnidirectional light output are BAD.
Bobby
Discussion Starter · #3 ·
Thanks for the input. This will be my first projector so i didn't know that.
From what i've heard the DA-Lite high power screens also make a difference.
Anybody out there own one?
1 - 3 of 3 Posts
Status
