1 - 2 of 2 Posts
Hello I set my 55 inch LG LV9500 on my bed(screen face down) to remount the TV stand and when I liftt it back up of course there's a crack. It's at the top center.. it's mostly just the bezel that's cracked to begin with but the screen is cracked as well. It still works perfectly fine, heck if you stand back 10 feet you literally can't even see it. There's usually some sort of glass/plastic in front of the actual screen right? I think maybe I got lucky because it still is in perfect working condition. Just wondering if there's some DIY kits out there to replace the front screen? And if not any ball park guess on how much it would be to fix it? I just replaced the TV anyways that's why I took it off my wall so it's not a huge deal.. was gunna stick it in the guest room though.
1 - 2 of 2 Posts
