Need a recommendation on antenna selection and design. I would like to get signal from towers in Baltimore (North-Northeast) and Washington DC (Southwest) 120-130 degrees apart. As a bonus, would like Annapolis towers (but, if not possible I can get PBS from Washington DC ). I am seeing atleast 4 High-VHF with more coming probably.
Is it better to go with two joined/combined unidirectional antennas (UHF and High-V)? If so, what do you recommend for an attic installation in my location? Or, a single bowtie style, multidirectional better and point it half way between Baltimore and DC (like 280 degrees)?
The attic is above 2nd story (about 25-30ft or so above ground). Lots of room available; large space most of width of house.
TVFool
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id=60ed432cc113e1
Vinyl siding, plywood, tyvec, HVAC in attic
Sending signal to a HDHomeRun and 3 TVs. 50 ft from antenna in attic to splitter in a smartpanel (via conduit from attic to basement), and another 50 ft from the splitter to the furthest TV.
I was thinking a 2 antenna design with very short equal length coax to a combiner, then into a pre-amp. Then put a signal boost in the basement at the splitter. What combiner/joiner is best for this? What else should I be thinking about?
TVFool
