My setup:
I am currently wirelessly streaming BR rip movies from my PC tower to a PS3. I have a gigabit connection from the PC to the router (D-Link DIR-825) which is broadcasting (5Ghz 'N') to a D-Link DAP-1522 bridge. Gigabit connection from the bridge to the PS3. The router is reporting a 70-75% connection with 240mbps, although I am realistic and don't expect that.
I had been ripping and compressing my BR movies to 4-8GB. I had never noticed any trouble with these because my network can easily handle the additional traffic if it had been doubling or tripling these. I recently purchased a 2TB HDD and decided to just rip and not compress a few of my favorites. So now instead of a 3-10Mbps stream I have 15-45Mbps streams. I am ripping them straight to an .m2ts container (AVC/AC3) when the original video codec is AVC and converting to .mp4 (AVC/AAC) with Ripbot if the original codec is VC-1. Neither container makes a difference.
What's happening is that when I stream these uncompressed BRs, the picture and audio stutter and jump (indicating a bit-starved network connection). When I check the bitrate reported by the PS3, it is showing 80-150Mbps. I have run these video files through Bitrate Viewer just to be sure, and they are all running at normal bitrates, i.e.
