Status
Not open for further replies.
1 - 2 of 2 Posts
Greetings
I have an old Barco 500. Over the past few weeks I have noticed that diagonal red lines have appeared and show up prominently on dark images. There are about 5 red parallel diagonal lines running / across the screen. I would assume that to a knowledgeable pj techie this is a common symptom of a going out pj but what would you say?
1. Are there adjustments I can make to lessen the effect?
2. Is there a certain part besides a tube that might be the culprit?
Any advice is welcome, good advice appreciated.
Have you seen your ISF tech lately? You may need a full gray-scale calibration. Better yet, save the $600 and get your own color analyzer. It could be on the verge of a scan fail. Check the hours on the tubes. I lost my Barco this year.:(
1 - 2 of 2 Posts
Status
