Status
Not open for further replies.
1 - 5 of 5 Posts
· Registered
Any ideas on this problem?
BarcoData 701s. Upon switching it on the unit does not light up. On the front, next to a row of green LED's which are all on, a red LED marked "Hold down EHT" remains lit.
· Registered
Hello Mark
When the Hold down EHT is on
To high beam current in a CRT
To high EHT from the feedback line
Rob
· Registered
Discussion Starter · #3 ·
Thanks Rob,
So is it a fault in the High Voltage power supply? What does EHT stand for?
· Registered
EHT is something like Electrical High Tension as I recall. I'd vote for one or more of the EHT board/circuit, quadrupler, and/or splitter has gone bad. The EHT holddown circuit is intended to prevent the highvoltage from shooting up out of the controlled range and producing harmful x-ray radiation. I've seen a splitter go bad and damage the EHT circuits. On the other hand, I suppose one of the tubes could go bad and short out the EHT voltage and am guessing that it would cause the same thing.
Mark
· Registered
Unfortunately, the Barco 701 is one of the few Barcos that is not modular, so it does not lend itself for board swapping.
you have high voltage failure somehow. Bad power supply, had horizontal stage, bad regulation, etc.
I have only worked on a few 701's so I do not have a good diagnosis here, sorry!
Curt
1 - 5 of 5 Posts
Status
