I bought a Barco Data 801s on Ebay for $1,075. It works great. Of course there was no remote control that came with it...
So I called the local distributor in Montreal to get a remote control for it... I fell off my chair. They wanted to have $500 (CDN mind you) for a remote control ... I don't think so Tim...
So here is my question.
I have a Denon RC8000 remote control. Does anyone know of a trick/way to get the proper codes for the Barco remote into my Denon remote?
I have another question which I posted on the HTPC forum, but may be more appropriate on this one, so here it goes:
My image coming from my HTPC is very soft and seemed out of focus (Main PC only - Image from PowerDVD is very crisp and clear) characters are out of focus and difficult to read. I am using a Radeon 7200 64M SDR with a HD15 to 5 BNCs connector.
Would a different cable be better; ie HD15 to DB9? I need to have 25' to 30' to connect to the HTPC.
Any suggestions, comments?
Sylvain Dumas
Sylvain Dumas
