I reset all memory blocks on a Barco 1200 to do a setup from scratch. Now I have a bad vertical linearity problem. The photo shows the upper part of the picture very compressed and the bottom so elongated that it goes well off the tube face. Frightenly far off. This photo was taken after doing a reset without doing any adjustments:
I can fix this by using a LOT (way too much) of linearity adjustment, and some (more than I would like to) raster shift adjustment.
Is there a pot that can help with this?
Note: Before resetting, I adjusted some pots (with positive results) as outlined in this thread: http://www.avsforum.com/avs-vb/showthread.php?t=780962
