got a barco vision 700 that has been sitting for a while, unit was put back into orriginal location and there is now a problem with composite video input. it syncs the signal but the color is off as well as occasionally the image will seperate (hard to explain). Also there is a blank spot on the right side of the screen, i set to midpossition and still have this issue. there is no problem with the internally generated patterns. tomorrow im going to test s-video and the RGB inputs, but in the meantime any input on what it could be?
unit is low hours, ~900. thanks
