Hi, Blue is way of as you can see. Cut off is set at 0. Can anyone help me ?
C charlez · Registered Joined Jul 2, 2003 · 47 Posts Discussion Starter • #1 • Jan 21, 2008 Hi, Blue is way of as you can see. Cut off is set at 0. Can anyone help me ?
C ChrisWiggles · Banned Joined Nov 14, 2002 · 20,735 Posts #2 • Jan 22, 2008 you'd just need to pull the gain down a tad, but blue will continue to fall off at high % unless you defocus a little bit the blue beam.
C charlez · Registered Joined Jul 2, 2003 · 47 Posts Discussion Starter • #3 • Jan 22, 2008 defocussing blue has some effect, but not enough
