Status
Not open for further replies.
1 - 4 of 4 Posts
· Registered
Are pros/cons of using WBT connectors vs. just bare wire ? I know on the amp side of things, I will most likely have to use spades or the like.
Any difference *sonically* if I use a similar connector vs. bare wire on the speaker side.
· Registered
What's a "WBT connector"?
· Registered
Jeez, why all the glitz? Just get some copper crimp-on spades. Solder them if you want the connection really secure, and use a colored heatshrink sleeve. Got be a LOT cheaper than the MBTs. You'll only be affected sonically by a poor or corroded connection, and soldered connections don't corrode or work loose, unlike screw-down connections.
Did I mention that you will save lots of money?
1 - 4 of 4 Posts
Status
