1 - 9 of 9 Posts
I've done a bunch of searching, but haven't come up with anything that directly addresses my question.
I just moved into a new house. It has radiant baseboard heaters throughout. There are 10+ dial type thermostats all through the house.
Is there a system out there that I can replace these thermostats with something more programable and controlable from my PC? More specifically, something that won't cost an arm and a leg?
$200 plus per unit is fine when it's a single controller for an HVAC house, but with 10+ to do, it could get a little silly.
TIAV
Discussion Starter · #2 ·
I've called X10, Smarthome, and come up with Bupkiss.
This maybe the first time the internet has let me down. I've always found that if I wanted to do something, someone else has too, and all I have to do is dig deep enough and I'll find an answer.
No suggestions, eh?
No suggestions, eh?
Post a pic of your units or at least a link to the style of thermostat you are indicating. These types of controls may be mechanical and may not lend themselves to easy upgrades.
Aube makes thermostats to control your baseboard heaters, and some have contacts for external control.
It will not be cheap.
Buy them from a reliable vendor or distributor, and he/she will provide guidance on installation.
You'll need a third party controller to control them all.
Read the manuals.
I have 2 zones of electric radiant floor heat in my master bathroom. The NuHeat thermostats are identical to a particular model of Aube thermostat, and although not detailed in my NuHeat manual, the Aube manual describes the contacts.
My thermostats are not currently integrated.
I think the Aube model are ~$100/thermostat, plus you'll need some sort of control system ($$$). You could prob get an HAI controller for $1000 (Lumina maybe?), and add some temperature sensors.
Discussion Starter · #5 ·
Thanks for the suggestions guys. It looks like individual programable units are my only option, unless I win the lottery ;-)
Maybe that $100/device estimate is a bit high, I think you can get them for cheaper.
Revised estimate ~$60/t-stat.
Keep us posted on what you end up with.
Maybe you don't need to have all 10 to be programmable. Before I moved in to my house, I thought I need to buy 2 programmable thermostats. But after I moved in, I found that we only go to 2nd floor when we go to bed. So it's always set to 61 degree in winter and no need to use a programmable thermostat. Perhaps you just have 3 or 4 zones in your house need the programmable ones then just replace those.
You could probably group the baseboard heaters to create 3-4 zones, or even 1 zone.
I have installed a few of the Aube stats, and tons of their other products, and they are excellent.
It's going back a ways, but I thought their programmable stats were even cheaper yet - I don't want to throw out a number because its pretty foggy.
Good luck
1 - 9 of 9 Posts
