Hi all, been a long time lurker but this is my first time posting.
This is going to be my first (very basic) home theatre project. Originally I wanted to go with a TV, but the prices for sizes over 80" got too out of hand for me so I decided on going the projector route. I've looked around online for a couple of days now so I think I've learned projector basics, however I'm sure there's a ton I still don't know.
Details of the project:
Lengths
Room Length = 20'
Room Wide = 12'
Room Height = 8' (vaulted ceiling to 12' in the middle)
Throw = ~18' (mounted above seating area at the back of the room)
Viewing distance = 15-20'
Screen size = 120" diag
Room Conditions
Colour = Grey (light) walls, white roof, beige carpet
Lighting = Two large windows on the side of the room, looking at installing blackout shades, dimmable lights
Price Range
$1000-$3000
Use
The main purpose would be to first: watch movies/TV shows with the Mrs, and second: to watch the game with my buddies. I'll probably occasionally watch regular TV but that will mostly be done on the family room TV. When watching movies we'll definitely have the shades drawn and all lights turned off. When watching the game I'd like to have at least some light in the room. Obviously picture quality will diminish but I don't think that will matter as much to us, as long as the picture is bright enough to see clearly from 15-20'.
Understanding that the room conditions aren't ideal (long throw length, light coloured walls/roof/carpet) it'd be nice to understand how much more I will benefit with a more expensive PJ? I did a quick search on projector central: http://www.projectorcentral.com/projectors.cfm?g=1&hide=0&st=1&mfg=&p=300&p=3000&w=&r=13&br=&ll=<g=&t=&db=&dt=&c=&ar=&dvi=&wr=&pjl=&pjw=&pjh=&td=18&i=d&is=160&sort=pop&sz=15 (I used a screen size of 160" diag and assumed I could zoom to a 120" screen, is that correct?) and a range of projectors came up. I'd like to know if there will be a considerable difference from the ~$1000-$1500 priced PJs (e.g. HD25-LV, 8350) to the more expensive $2500 priced ones (e.g. 5030UB, AE8000) with the conditions specified? If so what would the major differences be? I'm no videophile (is that a word?) so if the difference isn't very drastic I'd probably opt for a lower priced model. Also any advice on the setup would be appreciated! Thanks in advance.
BM
Lengths
Room Length = 20'
Room Wide = 12'
Room Conditions
Price Range
$1000-$3000
Use
BM
