14501 - 14520 of 15058 Posts
BassEQ Flash Gordon (1980) DTS-HD MA 5.1
BassEQ The Legend of Hercules (2014) Atmos
BassEQ Stardust (2007) DTS-HD MA 5.1
Okay, this was surprisingly a really good movie. Not a great deal of ULF as you can see from the heatmap, but it does have a couple of pretty good wobble moments that's worth noting.
Thanks again for another great BEQ Aron!
Darrell
  • Like
Reactions: aron7awol
Why do I keep getting errors merging with BEQ Designer? Yesterday was one, but today there are 6! See below....
bmiller_miniDSPBEQ - Movie BEQs - Flash Gordon (1980) (-0.5 gain) BEQ DTS-HD MA 5.1.xml - Different input filters found in C:\Users\G\.beq\bmiller_miniDSPBEQ\Movie BEQs\Flash Gordon (1980) (-0.5 gain) BEQ DTS-HD MA 5.1.xml - Input 1: {'1': {'freq': '120', 'q': '1', 'boost': '0.3', 'type': 'PK', 'bypass': '0'}, '6': {'freq': '38', 'q': '0.8', 'boost': '7.5', 'type': 'SL', 'bypass': '0'}, '7': {'freq': '38', 'q': '0.8', 'boost': '7.5', 'type': 'SL', 'bypass': '0'}, '8': {'freq': '38', 'q': '0.8', 'boost': '7.5', 'type': 'SL', 'bypass': '0'}, '9': {'freq': '38', 'q': '0.8', 'boost': '7.5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '10', 'q': '0.9', 'boost': '-6', 'type': 'SL', 'bypass': '0'}} - Input 2: {'1': {'freq': '35', 'q': '1', 'boost': '0.4', 'type': 'PK', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}}
bmiller_miniDSPBEQ - Movie BEQs - Hell or High Water (2016) (+5.5 gain) BEQ DTS-HD MA 5.1.xml - Different input filters found in C:\Users\G\.beq\bmiller_miniDSPBEQ\Movie BEQs\Hell or High Water (2016) (+5.5 gain) BEQ DTS-HD MA 5.1.xml - Input 1: {'1': {'freq': '80', 'q': '1', 'boost': '0.6', 'type': 'PK', 'bypass': '0'}, '6': {'freq': '35', 'q': '0.9', 'boost': '6.6', 'type': 'SL', 'bypass': '0'}, '7': {'freq': '35', 'q': '0.9', 'boost': '6.6', 'type': 'SL', 'bypass': '0'}, '8': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}} - Input 2: {'1': {'freq': '35', 'q': '1', 'boost': '0.4', 'type': 'PK', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}}
bmiller_miniDSPBEQ - Movie BEQs - Jeon Woochi (2009) (Korean) (+3.5 gain) BEQ DTS-HD MA 5.1.xml - Different input filters found in C:\Users\G\.beq\bmiller_miniDSPBEQ\Movie BEQs\Jeon Woochi (2009) (Korean) (+3.5 gain) BEQ DTS-HD MA 5.1.xml - Input 1: {'10': {'freq': '20', 'q': '0.7', 'boost': '5', 'type': 'SL', 'bypass': '0'}} - Input 2: {'1': {'freq': '35', 'q': '1', 'boost': '0.4', 'type': 'PK', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}}
bmiller_miniDSPBEQ - Movie BEQs - Stardust (2007) (-0.5 gain) BEQ DTS-HD MA 5.1.xml - Different input filters found in C:\Users\G\.beq\bmiller_miniDSPBEQ\Movie BEQs\Stardust (2007) (-0.5 gain) BEQ DTS-HD MA 5.1.xml - Input 1: {'1': {'freq': '52', 'q': '1', 'boost': '0.5', 'type': 'PK', 'bypass': '0'}, '2': {'freq': '10', 'q': '5', 'boost': '-14', 'type': 'PK', 'bypass': '0'}, '8': {'freq': '23', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '9': {'freq': '23', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '10', 'q': '0.9', 'boost': '6', 'type': 'SL', 'bypass': '0'}} - Input 2: {'1': {'freq': '35', 'q': '1', 'boost': '0.4', 'type': 'PK', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}}
bmiller_miniDSPBEQ - Movie BEQs - The Legend of Hercules (2014) (-2.5 gain) BEQ Atmos.xml - Different input filters found in C:\Users\G\.beq\bmiller_miniDSPBEQ\Movie BEQs\The Legend of Hercules (2014) (-2.5 gain) BEQ Atmos.xml - Input 1: {'1': {'freq': '50', 'q': '1', 'boost': '0.5', 'type': 'PK', 'bypass': '0'}, '8': {'freq': '22', 'q': '0.9', 'boost': '5.3', 'type': 'SL', 'bypass': '0'}, '9': {'freq': '22', 'q': '0.9', 'boost': '5.3', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '10', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}} - Input 2: {'1': {'freq': '35', 'q': '1', 'boost': '0.4', 'type': 'PK', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}}
bmiller_miniDSPBEQ - TV Shows BEQ - Penny Dreadful City of Angels (2020) (Season 1) (Amazon) (+5.5 gain) BEQ DD+.xml - Different input filters found in C:\Users\G\.beq\bmiller_miniDSPBEQ\TV Shows BEQ\Penny Dreadful City of Angels (2020) (Season 1) (Amazon) (+5.5 gain) BEQ DD+.xml - Input 1: {'1': {'freq': '50', 'q': '1', 'boost': '0.5', 'type': 'PK', 'bypass': '0'}, '8': {'freq': '25', 'q': '1', 'boost': '5.5', 'type': 'SL', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '4.3', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '4.3', 'type': 'SL', 'bypass': '0'}} - Input 2: {'1': {'freq': '35', 'q': '1', 'boost': '0.4', 'type': 'PK', 'bypass': '0'}, '9': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}, '10': {'freq': '11', 'q': '0.9', 'boost': '5', 'type': 'SL', 'bypass': '0'}}
the message means the filters in the config file has a different filter in input 1 vs input 2, merge process expects them to be the same or only one slot to have any (non bypassed, boost > 0) filters in it
in this case, input 2 has fewer active filters (peq 1, 9, 10 vs 1, 6, 7, 8, 9, 10)
i.e. file in repo needs a fix
Because new files are added with the same problem
Additionally: you can use the community made Preset Recorder program in the HTP-1 thread to add the ability to turn the HTP-1's PEQ on and off from a remote so that once done watching a movie you can simply have PEQ turn off (much like switching to an empty Config slot on the MiniDSP) with the click of a button.
With the Preset Recorder you can also make a remote control preset to zero all upper slot dB values instead of turning the PEQ fully off. (In case you want to use first PEQ slots for your own permanent corrections.)
Yes. These are the movies with the problematic files.
Flash Gordon
Hell or High Water
Jeon Woochi
Stardust
Premium Member
THANK YOU! Looks like you really were able to dig out some LFE from this anemic sounding movie. I cannot wait to re-watch what is widely considered by critics and viewers alike to be the greatest movie ever written, acted, and directed! ;)
At least the soundtrack is solid.
@3ll3d00d I just wondered why BEQd can't export biquad txt files for miniDsp. Sounds like a convenient way for me to load BEQs than via the XML. Is it a cross-compatibility thing? Could you possibly add that feature?
As Richard notes, it can do this already though I don't know how that is more convenient than the merge tool (I don't use a minidsp though ....)
^^^ I still use the save as biquads for my 10x10HD exlusively ! It is two seconds work before each movie i watch, but it loads INSTANT to the mDSP, while the merge way takes forever to load each file to the mDSP.
I know, i am quirky 😂😂
  • Like
Reactions: m0j0
Could've sworn I searched everything..! It convenient for me as I do my own BEQs on the fly for the German movies I watch. I have not used the merge tool and I have not looked at that yet, but exporting the biquads is really everything I need for maximum convenience. I change my miniDsp config a lot, so the XML files would quickly become outdated.
Flash Gordon
Hell or High Water
Jeon Woochi
Stardust
I don't know what's causing this is to happen. I'll take a look at them when I can but it's probably not going to be for a few days at least. I've been down sick with covid since the 20th and my head isn't 100% here for digging through data sets. So once my head's up to it I'll take a look.
Hope you feel better soon! What kind of symptoms etc are you experiencing if you don't mind me asking?
