I am trying to figure out if I can use the Audessey AS-EQ1 from SVS to EQ my subwoofers when used in a 2 channel and surround system.
My system:
For 2 channel, I'm using a Parasound 2100 preamp fed by a PS Audio DLIII connected to an Apple TV. The Parasound is connected to Paradigm Studio 20's and 2 Rythmik F12's. Additionally I have a Marantz SR5003 surround receiver that uses the HT bypass on the preamp.
Ideally I'd like to place the Audessey EQ between the preamp and 2 subwoofers. This would allow it to work for 2 channel audio and surround sound when the HT bypass is used. There would be no issue integrating the EQ into the surround system in this configuration, but I'm worried about the 8.5ms delay introduced by the EQ. The preamp does not have a way to introduce a delay into the front speakers like the surround processor does.
I'm wondering if the phase adjustment on the subs can compensate for the delay. And if it did, would it mess up the integration with the surround system. Anyone try this configuration? Do the other sub EQ's have less of a delay? I know I've seen people mention using the BFD or SMS-1 in a 2 channel system but I'm not sure how much of a delay these units have or whether these systems are also part of a surround system. Is the delay small enough that I don't need to worry about it?
Mike
My system:
Mike
