1 - 1 of 1 Posts
Discussion Starter #1
Hi,
So I have the Toshiba HD-A1 and will do an analogue 5.1 run to my [current] Outlaw 950 pre/pro. The Outlaw 950 does bass management on the 5.1 input (there is a switch on the back).
However, I also noticed in the Toshiba setup menu there are options for configuring speaker crossover as well as output per channel.
What are the most appropriate settings for this kind of configuration? Should I set the LF crossover at 80hz (I have that set on the reciever) also on the analog out? Or does my Outlaw do the bass management? Also, I assume I need to recalibrate the channel settings in the Toshiba settings?
George
1 - 1 of 1 Posts
