21 - 23 of 23 Posts
21DS115 is awesome driver, but I see it as such because NSW6021 is more than twice expensive than B&C one. You have it much closer, albeit Eminence not being on hand. 21DS115 definitely cannot do 20mm without ton of distortion and mainly power compression. You do not want to go above 17mm with this driver. I suggest that with up to 1000-1500W it is cheaper adequate choice, and at or past 1500W, it will start to lag most likeky.
Discussion Starter · #23 ·
I will be building the devastators fatboy V3, (X2) the B&C 21DS115-4 will be the driver, I will never push this driver in this box other then testing and setting the curves,
If I need more ill build another,
I understand the Eminence driver is better, BUT is better over 2000w and with a lower tune,
I won't be chasing those numbers
21 - 23 of 23 Posts
