Hi all,
I'm just about to mount my BD808 with unistrut.
I have a couple of questions though.
The screen width is 214cm (about 84") and the screen height is 115cm, going for an AR of 1.85:1 (bad idea, doesn't matter ?)
If I calculate with the LENS program, the PJ should be about 302cm from the screen and the A value is -22.7cm.
I hate that A value
If we look at a ceiling front mount and the A value is -22.7cm how long should the rods be ?
I want the screen to be about 40cm below the ceiling.
At the same time I want the rods to be as short as possible since the PJ will take "visual space" in the room if it's mounted low.
In the lens program it also states an angle of 10.5, is that the angle it will have or is it something that I need to angle myself ?
I hate that A value
