1 - 20 of 68 Posts
I just received it.
I didn't have time yet to check it out.
I put a picture of the box. It comes with a CD with a new update, the 2.21 version.
I am supposed to wait for Xmas but I may open it today and post some pics.
Cheers
Discussion Starter · #4 ·
It's region A, I live in Japan.
I did some quick test on it.
DVD Pal and ntsc works well
NTSC -> 1080/24p with a better image than the DVDO edge
Pal -> 1080i only but stunning image with 50Hz
Blu-ray, I tried Indiana Jones and Iron Man, no problem.
Loading around 14s for Iron Man
You can change in the menu the assignment of the two HDMI so
Main is for audio
Sub is for video
But you can do like me and connect main to the AV amp and then the TV and change the setting to have Main with audio and video
And the Sub is connected to my projector, it's a easy change
Very intersting point for me is the replay of BD-R AV recorded from cable TV.
It plays everything from 1080i MPEG2 initial broadcast in Japan to 1080i MPEG4 compression, even keep the bilinguial setting. I tried to put some BD-R with some 480i normal TV recorded on it and it's really better than the DVDO edge ( I tried some soccer ).
Sound is way better than my panasonic BD player (it's a player/recorder around 3000$ but you don't have it in US, must be the higher end player there).
The initial update from the CD took around 20mns. There is a home media gallery, video and audio to play from DVD-R or BD-R.
I couldn't test the BD-live because I don't have ethernet cable long enough.
CD plays through ananlog are really nice, much better than the marrantz DV9600 for example. Well I have a dedicated Accuphase SACD player so I don't bother much.
It output well every audio format through HDMI. I am sorry I didn't connect analog because it's a pain in the ass to put all those cable behind my rack. But, I rode a complete test in my usual japanese magasine and they said that the analog was the best for a blu-ray player yet, waiting for the new denon. However, if you use a Pioneer AV amp SC-09, or equivalent, they recommand to use HDMI because analog sounds more natural but less dynamic.
Using Analog with a Aurie Pre amp gave very nice results in the magasine but HDMI allows nice equalizer and stuff.
Anyway, watching Monsters Inc from 1080i broadcast (output 1080/60p) on a Pana 42 plasma, the image is unbelievable, popping 3D, great.
Tonight I will do more test on my projector.
I am very happy about it until now, it played everything I put in ( except region B Blu-ray).
If you have any question (if possible not about analog output because I didn't connected it yet, ask me). There is a preset for PDP, Pioneer PDP and Projector, LCD. The projector setting is made for Victor Projector.
Discussion Starter · #5 ·
I checked Hulk and Across the universe.
Accross the Universe is a nice Blu-ray to check the sound and OMG, it sounds so good and I knows well about sound, I have very nice audio equipment.
To test the dynamic and the bass, the best is the THX trailer at the beginning of Indiana Jones Blu-ray. If you compare with a PS3, the difference is as big than between a DVD and a Blu-ray.
Even my mom is hearing a huge difference,
OMG, this is a piece of dream this player.
If you want pic of something tell me
Cheers
Banned
Cheers
Ya that THX is something when played loud Pictures will be great. Did you buy it Online or a shop if bought online can you tell me that web page please.
Cheers
With such a beautiful BD player, I'm sure Santa won't mind if you open it up and take a few pics.
I see from the manual that it can output both HDMI Component 4:4:4 and 4:2:2 the questions is: which one for having the "deep color trick" i've read of (some sort of bit-boosting original color depth to 36bit, i think)?
Also: is there any visible difference when using this function?
Thx
The THX trailer on the Indiana Jones disc appears to be Dolby Digital and not TrueHD or DTS HD MA which is rather disappointing. Or is my player not picking up the right track? The movie itself is in lossless.
nippon, what's the power-on time ? i.e. from standby to disk tray open.
what's the "disc detection" time ? i.e. the time it takes to determine what disk it is, e.g. showing "BDMV" for BluRay and "DVD" for...dvd. For the LX71 it takes abt 40-45 seconds just to detect this, regardless whether it's BD, DVD or CD.
Does it already internally decode DTS HD MA ?
Can the 2 HDMI video output BOTH be active simultaneously ?
U say "projector setting is for Victor projector", do u mean JVC ?
Can u check in the audio/speaker setup, can it adjust levels for subwoofer ? (I want to add the +10db there, as my receiver cannot do this automatic gain)
Thanks a lot!
In the LX91 manual is written -6db/+6db for each channel, including subwoofer. The manual is online on Pioneer website.
No crossover setting/bass-boost for the analog outputs reported in the manual.
Discussion Starter · #12 ·
I know you are all crazy about time here even I think it s not important at all.
I check with dark knight which appears to be one of the slower
From standy to On 15s
From the time I close the tray the loading screen 17s
Loading screen was 16s.
Yes the THX trailer of Indi is in Dolby Digital only but hell it sounds good.
I didn't check the analog section
Victor is JVC in Japan. I bought it from Avac, expert AV shop in Japan, they don't sell international.
The video choose automaticaly 4:4:4. I don't know how many bits it's outputting because my projector is not telling me but the even I guess it's outputting only 10 or 12 bits because the VXP genum proc in my proj works in 10 bits like the realta. However the internal processing of the processor is in 16 bits which smooth and reduce the error a lot. A digital error on one unit in 16 bits is much less than in 8 bits.
I just finished watching Horton using the both HDMI with high speed and the image was really smooth and wonderfull. There is a big difference in the gradation in dark, the skin and the sky due to the 16 bits processing. I compare with PS3 and High end panasonic player. Sounds is really outstanding.
I will check the analog and tell you later.
Over my 100 blu-ray, they are working well.
I watched a Pal DVD and the noise reduction was so smooth, the detail really strong and no wrong line artefact at all. The best scalling in the house.
One interesting thing is that if you set the output to 1080/24p with a Pal DVD you will get 1080i/50 but if you choose 1080p you get 1080/50p
On the player screen, there is a little indicator which shows the frequency, 24, 50 and 60.
Outputting 24p from 1080i broadcast material looks great too.
But what I would say is the most impressive is that when the camera is moving a lot, the image stays on focus so much more than with any other player I saw, and I saw them all. And this 3D impression that there was already a bit on the last pioneer high end DVD player is here too.
I should play with the settings too.
Just to let you know my gear a little.
I use a SC-09 AV amp with a Accuphase E-550 Pre-main used for power-amp.
I use no center speaker, 4 surround and for the bass management I use a SMS-1 digital equalizer and a Velodyne HGS-18. Wireworld SS52 for video and Wireworld starlight 5 for the audio. Proj is JVC HD-100.
Even they say in the manual you can't have video on both HDMI output, if you use Pure Audio Off, I had images on both.
Pure Audio 1 is only audio (for CDs) and Pure Audio 2 is the one to use (HDMI video on SUB and HDMI audio on Main).
According to the manual you can choose either AUTO setting or "force" the 4:4:4 or 4:2:2 output. In my setup (vpr Sharp xv-z21000) 4:2:2 seems to work best but is very rare on BD players (they all output 4:4:4 to my knowledge, except the Panasonic).
Can't wait to read your impressions on analog output. The quality of the analog output is vital for me in buying this player since i don't have an hdmi processor and don't want to change it (is a McIntosh mx135). I'm especially interested on how the LFE channel will work on analog outputs.
Thx for your help and patience and ... a very merry Xmas
Discussion Starter · #14 ·
Alright I connected analog to give you some impressions.
For CDs, the quality is really very nice, I would say better than denon 3930
For Blu-ray and DVD, it's very nice and smooth, the best around. However you don't have equalizer, phase managment and things like Audissey, so the overall sound has less dynamic and spatialisation than through HDMI. However it's really good and if you must go through analog, I don't think there is better. The new denon maybe but it depends on your taste.
The analog part of pioneer is kind of very clean, a bit on the cold part, natural and smooth. I never liked Denon ananlog because they sound too warm, not focused enough and not clean.
For the bass management, the new firmware 2.24 doesn't have it yet.
I just bought a ethernet cable long enough.
I may repear myself, CD analog sounds really good, the best for a DVD player I ever heard (except Esoteric)
DTS-HD MA not yet too with analog. I just checked.
Hmm... surprising that you have better sound through HDMI than through analog outs. Especially considering the added expense of all those expensive DACs! What about the digital coax/optical audio out? How does that sound compared to HDMI and for that matter, the analog outs?
There are only two set-ups I can think of where the analogue outputs would sound better than HDMI.
1)Something like a Lexicon MC-12 HD.
It only supports LPCM HDMI. Recent reports have shown, such as with the PS3, there are real signs of jitter issues present in the sound.
Using the analogue outputs, may actually yield a better result with high quality DACs in the player. THe Lexicon provides full bass management, Room EQ and distance management via the analogue inputs.
2)With the processors DACs are inferior to the players and despite the potential loss of Room EQ, distance management and bass management, the difference is so great that it still sounds better!
Nippon. Is the remote backlit? The remote shown for the LX-91 on the Pioneer Japan website looks like it may be, while those that have received their LX-91's in the UK indicate the remote is the same as the LX-71.
Ordered my 09FD yesterday and was advised of mid-January arrival!
The LX91 actually have the possibility to set speakers distance and levels for each speaker (incouding subwoofer). Unfortunately no bass management and/or crossover settings.
thank you nippon for the details
I really wanted to get the LX91 so what you observed really helps.
abt the time, not that I'm extremely concerned, just that I want to see the LX91 uses a different drive than the 71. For what I see, 45 seconds to detect what type of disk is something pertaining to the drive itself not the software, and for the 71 it appears to me the drive is just simply too cautious. Now with the 91 it takes only 16 seconds, that's much better, in line with what I expect for a flagship.
For me the 91 is a perfect player: I need the 2 HDMI out for connecting to both a TV and a projector. And I have an amp that has no HDMI but has full 7.1 analogue in and it can apply all EQ/post processing in it. (Pio 59 txi / Ax10ai in your market). It's really gd to hear the analogue out is as gd as HDMI. And the 91 has level for subwoofer, that's another plus. (at least I can pre-boost the LFE in the player)
can't wait for my local launch (end Jan I hope)
Thanks for clearing that point up.
For me, a VERY interesting experiment would be for someone with a processor like the MC-12 HD to configure it up with both HDMI (LPCM) and analogue outputs...and A/B switch.
1 - 20 of 68 Posts
