561 - 580 of 887 Posts
RETIRED theater builder
Discussion Starter · #562 ·
Originally Posted by jimmyk36  /t/1464536/beam-and-pole-interruptu...fan23-launch-another-avs-ht/540#post_23594853
Theater looks great! Another fantastic Build!
How are the speaker stands built?
MDF boxes glued and nailed. Tossed a bag of sand intact in the bottom and filled the rest of the space with insulation. The result was an 80 lb. box.
Originally Posted by BIGmouthinDC  /t/1464536/beam-and-pole-interruptu...sfan23-launch-another-avs-ht/30#post_23145276
NYGF23 and I are keeping the budget in mind on this project and for the built in equipment rack are considering this "value". While the mid-atlantic slim 5 series with custom face plates is pretty slick (Staggered wall panel theater) it is going to run 2-3x this unit. Any other suggestions for a $500 rack complete are welcome
it is a 77 inch tall rack that I can pick up locally from an importer (HTdepot.com)
We will probably have to leave the back door off, we'll see.
Does anyone have a model number for the rack? I do not see this one on the HTDepot.com site. I see a $649 assembled one
OK - Big - gotta ask about screws again
for the 3/4" MDF. I am predrilling the holes when joining two pieces of MDF at a right angle and using 3" course drywall screws but when I put the screw into the end piece it cracks.
Just want to make sure to get the stands correct so they can hold the weight of the sand.
Can you go into more detail about the speaker stands?
Discussion Starter · #568 ·
Sorry there was a typo, I corrected it earlier today but you probably already started on your project. I just shot 2 inch 18 gauge finish nails in to hold it together until the glue dried.
I have used screws in the past for MDF but nothing longer than 1 5/8
Originally Posted by NYGIANTSFAN23  /t/1464536/beam-and-pole-interruptu...fan23-launch-another-avs-ht/570#post_23595954
Hopefully this Saturday
Sweet!!! looking forward to seeing it all done
Originally Posted by jimmyk36  /t/1464536/beam-and-pole-interruptu...fan23-launch-another-avs-ht/540#post_23595620
Might want to look into a Kreg kit
Banned
I've seen this problem with MDF. You can add a small strip glued and screwed so there is double amount of wood to catch. If there is plenty of glue it should grab and hold. You can even try a piece of non MDF and screw into that.
Technically the screws are just tiny permanent clamps. Once the glue dries your usually ok.
Originally Posted by BIGmouthinDC  /t/1464536/beam-and-pole-interruptu...fan23-launch-another-avs-ht/540#post_23593221
the riser is 11 and change deep.
I'm not qualified to advise you on the size of the riser vents but I got them here: http://www.hvacquick.com/products.php/residential/Grilles-Registers/Bar-Linear-Grilles/Dayus-Bar-Linear-FLOOR-Grilles-and-Registers#price
Select the floor return with no damper option, as it turns out they are made in Windsor, Canada.
http://www.hvacquick.com/catalog_files/Dayus_dafg_Cut_Sheet.pdf
in this picture you can see what started out as 12 ft boards and what we used for the center supports is the part we cut off.
I ordered some Riser Vents from the site you linked. Funny story here. The place that manufactures them is 10 miles from my house. I called them but they do not sell directly to customers but gave me two places locally that do sell them. It was cheaper to order them through your link, ship them to the United States where I have a UPS box, pay the taxes in Canada when I cross the border and bring them home by a fair margin in comparison to picking them up at a retailer local to my home. Sad.
Looks awesome guys, thanks for all the pics.
Great job guys and just in time for football!
I have to say Thursday is going to be a special day for me even if it's only preseason.
Originally Posted by booga24  /t/1464536/beam-and-pole-interruptu...fan23-launch-another-avs-ht/540#post_23593264
WOW!!!!!! Great job guys, theater is looking awesome. nygiantsfan23 which paint colors did you use walls and ceiling?
Sorry for the delay, it's sherewin Williams Turkish coffe and jersey cream
Originally Posted by NYGIANTSFAN23  /t/1464536/beam-and-pole-interruptu...fan23-launch-another-avs-ht/570#post_23603094
Thanks giantsfan23, I love your colors.
