Would you mind giving me some links to what you used for the light? The pipe is straightforward enough but I'm not positive how to make the transition to the light socket.I'm getting close to being able to have the pool table moved! I built the light fixture that will go over the pool table. I was able to build it for 1/3 the cost of what the Etsy seller was asking. It weighs about 50 lbs. Fortunately during my build I put a ceiling fan box in this location that is capable of holding a 210 lb static load. The only thing I would have done different would be to use a 5" and 3" piece of pipe instead of 4" and 4" on the 2 lights that sit higher than the other 4 lights. That would have centered them a bit better between the lower lights.
And I absolutely LOVE how your rooms look.
