1 - 2 of 2 Posts
Hello all,
I am from india.
Actually i am totally new to this field.
My question is :
I have Yamaha 5.1 system.
AVR : HTR-2067
SUBWOOFER : YST-SW315
Speaker : NS-555(FRONT L AND R)
NS-C444 CENTRE SPEAKER
NS-333 sourround L and R.
I want to pre wire for this system as ceileng have to be closed.
Kindly give me advice for what wires and cables to run.
Projector and screen is not yet decided.
Room size is 26ft by 14ft.
Please give advice as soon as possible.
Regards.
RETIRED theater builder
speaker placement is dependent on seating location and number of rows, do you have a room layout plan?
speaker placement is also dependent on Screen Type, acoustically transparent or not?
Projector location is dependent on screen size and brand they are not all the same so wiring for a projector is a guess at best if you don't know, do you have a short list? Screen size is dependent on viewing distances so back to number 1. Do you have a room plan?
1 - 2 of 2 Posts
